Duramax Sound Deadening-19 dB
I finished my 3 week project, entire interior removal.
Did the complete sound system overhaul, TNR, and sound reduction treatment, trying to leave no stone unturned. My results overall, using the radio shack SPL meter, C weighted:
Idle Before: 77 dB
Idle after: 58 dB (this is 4-5 dB quieter than my wife's Expedition)
19 dB reduction
Average road noise reduction is 14-20 dB
Call guiness.
I used approx:
150 sf of Dynamat Extreme
60 sf of peel and Seal
15 sf of HTM (mcmaster)
6 cans of PU expansion foam
200 cubic feet of yellow fiberglass batting (compressed it is like 10-20 cubic ft)
25 sf of 1/2" sound barrier decouple foam ( 1 lb/sf barrier sandwiched between 2 layers of foam).
total cost was about $500, about 60 hours (a nightmare). Added weight is about 100 lbs.
Now on to the performance exhaust with 2 mufflers.
Wow man! That's f'n awesome! Sounds like you did a good job. I wish I had dynamatted my cab when I installed my amp/subs/comps. Did you apply a layer of each material over the entire cab?
No, I used various materials where I thought they would perform best, including some external treatment.
Opening day today, took my son to the game, Cubs killed us. Anyway, he cracked the door on the highway, I thought, what happened to my quiet truck? That thing is sealed up!. My ears pop when I close the door.
I also spent some time making the air fan quieter using some fiberglass and foam to deaden that immediate area. Used to swooooosh much more. It is easy to "never stop".
What is "peel & seal" & how does it differ from dynamat ?
What it the thickness (single layer) of the peel & seal ?
Do you have Link to a website for more info & availability?
Do you have a Mcmaster part # for the HTM ?
How many layers of the above did you install ?
I am planning a sound system upgrade and 1st step is to include a sound insulation barrier.
I have ample supply of PSA backed neoprene sheet rubber 1/16" & 1/8" thick and PSA backed closed cell foam rubber I was thinking about using. I can get both in long rolls and 36" & 48" widths.
I have heard that you can use roofing underlayment (ICE dam) bitumen based.
Im looking for lower cost than Dynamat
Closed cell is fairly worthless for sound absorbing, and at those thicknesses, a worthless effort. It may, however, be a resonant dampener, if it is heavy!! Not trying to be condescending, just keep you from wasting your effort.
It was a long project, for my money, here is what I concluded. Dynamat, bought off ebay for $3 psf is hard to beat. There are competitors, but I found out how much I love the stuff when i did some testing. It is more visco-elastic than anything else.
What I liked was how inexpensive plain ol fiberglass batting was, and when compressed 3x, it absorbed better than anything else I tried included a foam-vinyl-foam composite at $10 psf. The niche for the composite was the floors, since, at less than 1/2", it is, hands down, the best 1/2" treatment for sound blockage there is. You would need 2-3" of compressed fiberglass to equal it. Ever see those compressed fiberglass cieling tiles for noise deadening? Same concept.
P & S is a construction material used in flashing I think, is thinner than dynamat extreme (.070), about .040 thick, and if I did this over, I would not buy it, it is ok, but does not adhere nearly as well as dynamat. My hunch is that it doesn't dampen nearly as well. But if you want it, many lowes or HD's carry it, and there is one mail order place I will get if needed. Still, at $1.50 psf I don't feel it was a value.
HTM is the worse for adhering (so only use it with a heat gun, roller and in flat areas, like the roof.) but it wll stay put if you don't use it in complex 3D areas. And it is an extremely good dampener.
In my truck, almost every sq in of area got covered. The interior sat in my garage for 2 weeks (and it apears some crawled up into one of my seat and died, cant find the source of the decomposing smell!). The most resonant areas, to cover twice would be each floor pan where the feet go, these 4 places seem very unreinforced and resonant. The back wall is huge, pay a lot of attention there. On each door I did both door skins, trying to seal up any holes on the interior skin for audio performance. Do not attempt to remove the headliner from the truck, but you can drop it pretty easy. Do this area, it is very, very resonant. I used about 2-3" of fiberglass adhered to the top of the liner before replacing it. Make sure you have 2-3 helpers when you put it back up.
I stuffed fiberglass in every ineterior hollow opening I could access. I used alot. I would also use it (or a good PU acoustic absorbing foam) on every door panel, use 3m spray adhesive to attach it to the interior panel before putting it back on, huge acoustic performance benefits also.
I obtained a 2dB interior improvement by adjusting my hood latch believe it or not (diesel thing)
i will go find the mcmaster part # for the HTM.
I took a ton of pics.
You did not plug up your door drains did you? If so, you will want to unplug them, or within two years you will have BIG rusty holes in the bottom of your doors. During rain storms, melting snow and ice, car wahses, etc... some water does get into the door, and those drains allow it to drain off instead of collecting. With all the stuff you shoved in there, you will never here the water sloshing around to let you know you have a problem.
Nope, wouldn't do that. Had some rain while doing the project, and water does come in. Also makes its way into the kick panel areas, that's not right! Haven't quite figured out where it is coming in from.
That is a good point about water in the doors. Don't use anything in there that will mold. Open cell foam at 2 lb/ft^3 seems to be the ideal weight for absorbtion. But as we know open cell is like a sponge with water. Some people discard the plastic liner. I preserved the plastic liner and put it back, highly recommend this if attacjhing foam or fiberglass to the door panel.
Could you go into more detail of what you did with the roof/headliner. I understand that removal and replacement is a PITA. One small area at a time? Did you use regular R-22 and stuff it in or use adhesive? What's the process? What about Dynamat on the roof? Thanks.
I dropped the headliner in the vehicle, after the entire interior was removed. Don't try to pull it out. Will ruin it.
From the doorways of the vehicle, I put patches of HTM on the roof skin, then roll solid covering of Dyn Xtreme over that, sections at a time. I used a spray adhesive to tack the fiberglass batting to the headliner. Anywhere from 2-5 inches depending on the "hollow space" that exists above the headliner.
When removing, then replacing headliner, get 2-3 helpers.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,278 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
