Just Installed Access Cover
Installation wasn't too bad, They did short me one nut but luckily I was able to find one in my tool box. This is a nice cover as it is lockable (I also put in a Pop Lock tail gate lock). You can also adjust it to the tension you need. And the best part is that I can roll it up and haul anything I want without it taking up hardly any room in the front of the box! I got the limited editon access off of ebay for $385 shipped.
Now I need to find some more gadgets to put on!!
I got it on ebay from tonnoman, this is actually Real Truck as seen in the left hand side of this site. I got a better price but I was the only one to bid on it. He did have quite a few of each cover he sells so being the only bidder shouldn't be too much of a problem. I also emailed him after the auction and purchased a pop lock which was also included with free shipping!! And yes it does come with 2 seals. The directions only referred to one but I used them both. I also reccommend the pop lock so you can lock the whole bed of your truck.
I've had an access cover on my truck since I bought it in 02 and I like it alot, picked it up at a local store for around the same. It comes with weather stripping on it but I went to Home depot and picked up some rv weather stripping and ran it around the bed rails just for an extra water tight seal. I was gonna put a pop lock on it but after having a freinds soft cover of a different brand get cut open which was a total loss. If someones wants something bad enough they will get it reguardless.
