Electric Side Windows
I think my switch control for my side mirrors has problems. Probably got wet or something. Is it easy to replace? Where can I get a new one? Not really wanting to go to the dealer :banghead:
For both mirrors, they don't go down or to the right. They did work going up and to the left.
Thanks!
-w
I think my switch control for my side mirrors has problems. Probably got wet or something. Is it easy to replace? Where can I get a new one? Not really wanting to go to the dealer :thumbs:
Thanks!
-w
not sure how mechanically inclined you are...
my truck did the same thing when I purchased it, a drink or something had spilled down in there.
you can pry up the little panel that the mirror control sits on, then pop the switch box off the panel. I pulled mine apart and used rubbing alcohol and qtips to clean all the contact areas, put everything back together and it's working fine.
good luck.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
