mind taking a look?
I have a question in the classic trucks thread, but it's about a 97 truck (won't run after changing intake gaskets). I know this thread gets more traffic, so I thought I'd post this here to ask you guys to take a look too.
If this is bad form, please let me know, and I apologize in advance/won't do it again.
Thanks,
Jon
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
