Anyone have eagle 101s or 194s
What is the offset of your wheels? I'm looking at buying some 16x8 wheels with the following offset and backspace for a 2500 HD:
Offset -20 backspace 3 5/8 "
I dont want the wheels/tires to stick out too much.
I have the 194's on my 04 HD. The specs are as follwed: +2mm offset and 4.5" backspace. Here's a shot of my truck head on after the rims and 265/75's were installed. You can't get a great depiction of the width but they basically stick out just a little from the wheel wells and are a seemingly perfect fit for my likings.
OK..Here goes...Eagle 101's have a 3 5/8 backspace. Will it work? Yes. Will you have to do some t-bar cranking and cutting? Absolutely. Will they stick out? Yes. I'll give you a hint. I had Eagle 101's and switched to American racing Baja because the Baja has a 4.5 backspace. This made everything really easy and the fit was much better. Slight trimming and a couple of turns on the t-bars. I did not have to go crazy like I did with the 101's. Just my .02 :confused:
i have the 101's and the fit pretty good...had to crank the t-bar till the front raised an inch and a half and trim the fron valance thing. it rubs a tinny bit in reverse if i punch it but thats about all. they stick out a little but thats they way i wanted it to look. i would say the tires stick out about 2 inches from the wheel well moldings.
