OEM connector part #'s
looking for 2 part #'s please. First one is the 24 way GM radio connector (female). The one that plugs into the radio/AMP. The other one is the "PINS" that push into that harness. Dont need the harness itself, just the connector and PIN #'s.
Also, is there a way to tap into the OEM DVD console as far as the monitor is concerned. I want to run multiple monitors from the factory DVD system. Anyone been able to tap into that harness, if so, how?
Thanks
See if this helps. What I did is take a RCA wire splice into the video+ and video- on the splitter box found in the RSE dvd console, then run it to your video amplifer which will allow you run more then one monitor. Hope this helps.
Thanks
The pins are no. 12089649, that is a bag of ten.
24 pin amp connector is no. 12110088
Just a heads up, that part number for the connector does not come with the little "comb" like snap-in pieces that hold the pins in. This is another part number for the same style connector that should come with the finger pieces......if anyone knows the part number(s) for the finger, (comb) like pieces that hold the pins in, let me know please.
24 way connector - 12110206
