hard starting when hot
tonyk
i own a 99 silverado, 2 wheel drive,5.3l. i have recently changed the throttle positioning sensor because of eratic idle. that solved that problem. now as of this week my pickup is sometimes hard to start when the engine is hot. it fires right up when it is cold but i have to grind for a min to get it going when it is up to operating temp. i would appreciate any thughts or tips. thanks
My truck is doing the same thing as of this weekend. I have a 2000 Yukon and it starts just fine when ever the engine has time to sit and get cold. However if I just run in a store I have to grind it to start it.
I would really appreciate any advice also.
BigDaddyYukon
  • 5 months later...
BigDaddyYukon
My truck is having the same hard starting problem when it is hot. I have a 2000 GMC Sierra, 5.3 L with 99,000 miles. I changed the spark plugs, fuel filter, and PVC valve about (3) months ago but the problem didn't show up until about (3) weeks ago. Any advice as to waht to look for would be great
Possibly a leaking fuel pressure regulator. Under the conditions in which this occurs, pull the vacuum line of the regulator and look for wetness in the hose or coming out of the regulator pipe.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 457 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
