Wix Filters
I went to napa to get a oil filter for my 05 and asked for a wix filter and they handed me a napa gold filter, and said that it was a wix filter and that they are made by napa.So is this the truth or did i get the wrong filter, i would of thought wix would be printed on it somewhere but i dont see it?
Wix and Napa Gold are the same filter made by the same company. If you really want to know more about oils and filters and such here is the obligitory link to:
http://www.bobistheoilguy.com/
BTW, I always use the wix/napa gold's. It is very highly rated by all of those lube geeks at the site.
:cheers:
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
