Introduction to Keyloggers
Bgdsub72
Please note that spyware is largely, but not exclusively, a problem with Microsoft's Internet Explorer. The user of more modern, feature-rich browsers such as Mozilla Firefox can virtually eliminate the spyware problem altogether. However, it is still the case that some websites are coded to only work with IE, and therefore switching to Firefox may not be a solution for 100% of a user's web surfing needs.
One word for the internet needs: Mozilla!!
think i'm going to delete the E off my desktop and get foxfire. that way if the girl surf they'll have to learn foxfire and if I need to use IE i can get it from the program menu.
That's how it's set up here :chevy:
