I'm New Here.....
Hi everyone,
I Just wanted to say hi and let you know I'm new here. I really enjoy this site and I'm a proud Chevy Z71 owner...However I have a slight dilemma....not a bad one though..Wouldn't mind hearing your opinions on this:
I currently own a '93 Z71 Stepside...Single cab, Indigo blue in very good condition. It's been garage kept since I got it in late '92.  It hit 92000k highway miles on it and the only problem it's ever had was that the water pump needed replacement and minor maintenence issues such as battery replacment and alignment.  The mods I have on it are Gibson cat-back exhaust, smittybuilt nerf bars, and a Manik grille/brush guard..Future mods would be a 4" rancho lift, 33" tires and cool wheels....However, lately I've been toying with the idea of getting a new silverado...But everytime I get ready to go down to the dealer and buy a new one it seems someone always says something like "keep it..it's in great condition for it's age"..Plus the fact I'd probably miss it and would be pissed if someone bought it and trashed it....I'd like to have the extra cab which I'm sorry I didn't get originally but it would probably only be used to throw my dog in back or occasionally haul my drumset...So I have some things to think about. :)
What do you think? I can post a pic of my ride when I figure out how...Keep up the great job on the site!
Joe
Welcome to the forum. Sounds like you have a very nice truck and I am looking forward to seeing the pics. I guess if you are happy with your truck then keep it. If you feel like it is time to move on then do so. Keep in mind the dealer will give you nothing compaired to what your truck is worth. If you are ready to move on then you will do your best by selling it on your own then using the money as a down payment. That way you can be kind of selective as to who gets your baby.
Welcome to the Forum Joe!
Sounds like a nice truck.  If you've got the fever for a new ride and can't keep the current truck, I'd say sell it yourself.  That way you decide who gets it and you'll get more than you would from a dealer trading it in.  If you sell it, sure you'll miss it.  But I have a feeling you'll get over it quickly when you're running around sporting a new truck!  Not an easy choice, but best of luck deciding -
After just reading John's reply, its obvious Joe, that great minds think alike.  And so do John and I! -
welcome. if i were you, id keep the truck you have and buy a new one. now interest rates are so good and leases arent bad too, it may be worth your while to keep your old truck until you decide what to do with it. like the others said the dealer wont give you crap for it. i had a '77 impala. my granddad gave it to me. it had 100,000 original miles on it. custom paint, new interior, custom rimms, low pro tires, tint, stereo. nice car, i got offered $500.00 from the dealer! i sold it outright for $2,500.00. however, i wish i still had the car today.
Welcome Joe.
I am with Big Punn with as low as interest rates are and with rebates if there's anyway to keep both that's what I'd do.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
