Performance 350 Pre-Vortec Rebuild?
Dear Group,
I have a 1995 Chev Suburban 4X4 @ 225K with the 350ci V8. The transmission is due for a rebuild and I was thinking of doing the engine at the same time along with some performance modifications, such as cam, intake, headers, exhaust, custom tune.
This is the pre-Vortec engine and non-electronic tranny. I presently have a TCI shift kit installed in the tranny. Powertrax locker in rear diff.
Is it reasonable to expect good results on money spent or would it be better to trade in my ol' workhorse for a newer model before comtemplating these modifications? Would a crate engine such as offered from GM parts or Edlebrock be a prefferred alternative?
I have kept the rest of the truck in good condition. Used as an every day driver, several loaded longer trips a year (5K), and going through trails and bush year round to/from lake for kayaking and mountain biking. Sees a fair bit of winter snow driving.
Appreciate any input.
Thanks,
Glenn
Dear Group,
Thanks,
Glenn
THere is nothing wrong with a 350 TBI with a little cam work and a better intake and maybe a over sized TBI unit to. Edlebrock makes one for it that is designed 87 thru 95 TBI engines. Be carefull with with header and dual exhausts be cause it can hurt low speed torque if not done and tuned (the exhaust system) correctly.
I have a 1995 Yukon with the same engine. Banks headers, exhaust, and intake really woke it up. It runs very strong at 110K miles. So yes, some goodies will help.
As always, it's all about money. You could rebuild what you have, get a crate motor, or get a custom motor. A quality rebuild with a few goodies may be what you are after, when balancing price and return on investment.
you can even convert it to be a vortec 350 without spending alot of money.
Hi Mudbug,
Where would I begin a search for the conversion to the Vortec?
Thanks,
Glenn
Hi Mule,
Wow! That's a long list of mods for your truck! Very impressive! Would like seeing a pic of your truck. I looked at two links, but they were showing no image available.
Did your vehicle come with the 4L6OE transmission or was that a conversion?
Thanks,
Glenn
Thanks Snoman,
I'll check out the Edlebrock site. Thanks for the warning regarding the exhaust.
Glenn
gmpartsdepot.com has the intake maniflod that will fit a tbi and the vortec cylinder heads.
Yes but the TBI one is factory OEM unit and not worth the purchase as it is "stock". You want the Eldebrock one for a TBI engine.
i've helped 2 guys do this swap so far. the most important thing in making this work is getting the chip right when you're done. the stock chip just kills the power. it's way too lean and the timing curve is way off due to the faster burning combustion chamber in the vortec head.
Take a hard look at crate engine vs rebuild. Depending on the going rate for machine work in your area, it may be cheaper to buy a new long block, then put your goodies on it.
Around here, it's not worth the money to do stock rebuilds. Crate engines are actually a little cheaper than a complete teardown and rebuild.
Maybe if you farm out the rebuild completely but not if you do the work yourself except for the machining. I can rebuild one myself cheaper and better than a crate motor as long as you have a good block/motor to start with. (one that has not been blown and damaged)
Good point, about the two. If you check with painless wiring, they have conversion kits used to install TBI in pre model trucks/cars. I saw one kit used on a early car on the show Horsepower TV, or Trucks TV. you can check their web site, they normally have everything listed there.
Hi Mule,
Thanks,
Glenn
Glenn,
The transmission is what came with it. The website that hosted my pictures went down, so I don't have any right now. It is white.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
