Possible Fender Damage!!
hey yall
i lifted my truck 6 inches and now im having some problems.. i put 35 in tires on it and now whenever i hit a bump my front fender rubs against the tire.. see Pic
Is there any way i can fix this without totally cutting out the fender..?
Pic of fender!
Pic of my truck
:P
hey yall
Pic of fender!
Pic of my truck
:P
Yes, raise truck more or put on smaller tires. You could try limiting spring compression down travel but then it would ride bad and still likely rub. You simple do not have enough clearance for the rubber you are running, sorry!
Looks like you will have to trim some. Cranking the t-bars may give you a bit more lift and in turn more clearance, but probably won't allow you to clear the tires. I know cutting the front bumper and fender is not what you want to do but it may be a nessacary evil. I had to trim up my 03's valance and again at the back fender even after cranking up my t-bars to 7-8ish inches to clear my 35's.
Yes three choices here maybe, raise truck/body more through a bigger lift, trim some metal or install smaller rubber. There is no easy fix here to keep rubber in current configuration and not have clearance problems.
hmm well thanks everyone..
do you think if i need to trim some of my fineder should i have someone do it or is it just as easy to use a saw tirm it, paint it, then cover it with some fender flares?
I would buy the saw if you do not have one and trim it yourself and then paint and add the right flares and it should look pretty natural (like the tire belong on truck if trimmed and flared right)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
