Allison 6-speed for 06
This is the way I enterpret it. Correct me if I am wrong. Instead of using the column-shifter to hold gears, you now shift it to "M" and use the +/- buttons for the same process.
Current 5 speed
Move the column to "1"= holds first
Move the column to "2"= holds second
Move the column to "3"= holds third
Press the OD cancelation button = holds fourth
Move the column to "D"= holds fifth
New 6 speed
Use the "M" and the +/- buttons to do the same thing
I know the current tranny already has grade braking and cruise braking for the diesels, so it sounds like the new tranny is alot the same, except for the extra overdrive gear.
    MANGOAL
    MANGOAL
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
