Wester's Q?
I am seriously thinking about installing Westers on my truck. I had Hypertech on my 04 and was not impressed other than the rev limiter and shift points. However, I was able to put it back to stock when I took it to the dealer for different issues. How do you deal with that issue (putting it back to stock) when you have a Westers custom PCM when taking the vehicle to the dealer for whatever reasons? so your warranty doesn't get voided-- thanks
Search the forum - the general opinion is that the tech's won't be able to tell the difference b/t a stock PCM and the Westers PCM. Now bear in mind if they decide to flash your PCM in the attempt to fix the issue (yep, software fixes all hardware issues - or at least that's what engineers believe) then you lose the tune.
I've got a Westers with 40k+ on my extended warranty to go.
You can always ship your tuned PCM to westers and they will ship you back a stock pcm. After the warranty work is done you can have them ship your tuned pcm back. All you have to do is pay for shipping. I got mine ordered yesterday, should be here next week.
If you look on the web, you can find replacement cores for under $200. I kept my original cpu and the two times I've been in, I pooped my stock cpu back in.
It takes less than 5 minutes, and they can flash all they want.
Wester's will send you a new tune for free, but there's the hassle of time, mailing, shipping charges, etc.
Play safe and keep a spare.
The dealer "flashed" my westers when I had it in for it's final warranty service on my old truck.
That worked out Ok though, because I wanted a few changes to my custom tune, so I just called Lyndon, and he set me up with another PCM for $45 plus return shipping of the "reflashed" old core...
I hate to ask where you keep it when you're not using it.
:lol::P:wtf:
:wtf::lol:
danm spell checker :P
Umm... it stays on a shelf in a box ?!!? The cpu, not the poop....
Sorry dude, but the smartass in me had to act upon it.
:D:fume::wtf:
Thanks MrQuad. So I guess it would not be too bad of an idea just to eat the core charge and keep the stock pcm. What part of the pcm is replaced? the entire box under the hood or what?? any pictures? thanks
Glock, definetely find you a core on the net. Wester's charges $300 for a core, I KNOW they can be had for under $200 with a little effort.
Yes, it's the entire cpu, located behind the driver's headlight. Once you've done it, you can swap cpu's in under 5 minutes.
I have pics at home. I'll POP them up tonight.
POP.
POP.
Not poop.
???? I can't find my pics ???? WTF ????
I'll find them.... tomorrow :fume:!!!!
Look behind the driver's headlight, under the black plastic cover. The cpu snaps in and out, the only tool needed is a 7mm nutdriver for the wiring harness connectors.
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 576 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
