Magnet in G80 drain plug?
I recently changed the rear end oil in my 04 GMC 2500HD G80-4:10 locker and I was surprised to see that there was no magnet on the drain plug. Should I have had a magnet, or are they all like that? Also, it would only take 3 qts of oil, I thought it was supposed to hold 4. Any ideas?
thanks
The magnet is inside on the housing,not on the drain plug,you have to remove the cover to get to it.
thanks
Just curious about what oil you used.
I used Mobil1 75-90 in mine. You are supposed to go out and make a few turns (figure 8's are the best), then check the fluid and add as neccessary. The fluid has to make it's way around in there a bit. I can't remember exactly how much fluid mine took though. Maybe someone else here will help out.
4qts. put the level about 1/4" below the fill hole on my truck. 2qts. puts the level about 1/4" below the fill hole on the front diff.
I used Royal Purple Max-gear 75w-90 in the rear and M1 75w-90 in the front.
I wanted the same fluid in both,but none of the parts stores in my area had enough of either to do both.
is it just me or does having tp drop the cover to clean off the magnet sound like a bad ideal? or am I reading this wrong? any know if any one makes magnetic drail plugs?
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 399 Guests (See full list)
