I want to add some 305's on my truck but don't want to lift
6" is this possible. I am not big on the idea of cranking the torsion
bars. Also can I run these tires with out to big of a performance loss
with my stock 4:10's or should I just go with the 285's thing to ponder
for the experts @gm-truck.com :D:cry:
I wouldn't mind running that size tire on my Sierra as well :D - I don't mind cranking the bars, I just don't think I'm ready for a body lift or anything.
HD's have alot more space than my 1/2ton. I would think you would have to crank the tbar to the max on my truck. :D What do you guy's think about the performance side? :cry:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
