'05 Crew Cab Problems!
First the CD Player would not play or even switch to cd mode with a disc in. I pulled all radio fuses and put them back in. All good. Then I had a cd playing and I muted it and after a couple minutes the radio switched on and the clock reset to 12:00. Now I have no CD or XM Radio!!!
So I get home and wash the truck and notice there is some cracking paint on the bottom rear of the back door frames. Where the sill is welded to the upright supports.
I am definately taking it in but has anyone had these problems??
I am really pissed with the quality of this truck. I have a 10 year old truck that is finally having paint crack - but a 5 month old truck?
Where was your truck built? I'll bet the paint quality of various 2005 trucks corresponds with build plant.
(My 2005 2500HD, gunmetal gray, was built in Pontiac, MI.)
May radio stop playing and reset the clock to 12:00 just once last fall. I have no similar problems since.....my inital thought was the problem occurred because of a burned CD but I may be wrong
I don't want to hyjack this thread but, I had the same problem as SLEDR did. It's happened twice since I bought the truck 1 year ago. It just powered down and the clock went to 12:00, but all my presets were saved...odd.
Jeff
Jeff
at the dealer i seen this alot the gm radios seem to have all sorts of probs. cds stuck in player, display says (lock), and i always seem to see the paint pelling off on the radio buttons, they dont have a fix for it we end up sending everyone of them to the ac delco repair phacility (sorry cant spell that word.lol) and get a new one.
Delphi has had a lot of difficulty with paint on the buttons lately. It's a combination of things they don't have a handle on yet...that's all I'm at liberty to say. Even the pricey NAV radios have the same problem.
My CD player died after 5 months in my '05 and the chime never seems to know how it wants to function. I'm hoping when I get one of the NAV radios and the 6 disc changer my problems go away.
The paint on my truck is okay, but seems a bit on the soft side. My truck came from Canada.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
