Blower motor resistor problems!!
I have a 1996 GMC Sierra and have had the blower motor replaced approx every year and a half at the dealership (quite costly). Once again it now only works on high speed so purchaced the resistor to replace myself.
I located the resistor (behind the glovebox) and disconnected it to remove it. Here is my problem, there is not enough room to remove the resistor once unscrewed! Do you have to remove the whole upper dash to access it? I attempted to investigate this option, looks difficult. Any help?
