3" PA Body lift
I am looking into adding a 3" body lift as an alternative to buying a suspension lift (new baby = no money).  How have you guys handled the brackets on the front bumper that show after the lift?  Do you cut them off or cut the plastic?
Thanks for the replies.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
