88 GMC Idle problem
Will
I’m having a problem with my ’88 GMC 1500. First off the problem occurs simultaneously with the service engine soon coming on. The idle on the truck is very erratic to say the least. While sitting at a stop light I have to keep my foot firmly planted on the brake pedal to keep it in place. If I put it in neutral it will rev way up and then down and then way up again. While driving it will almost stall and then pick back up. I’ve had this problem in an Oldsmobile, fuel injected, it was the idle control valve. However, I am not sure if my truck has an idle control valve?
Need any and all help, working on a tight budget.
Thanks.
The first step would be to see what code is stored. I suspect you might get a MAP code, which would not be unusual with that type of idle condition. In that case, the MAP code would probably be a result of the idle, not the cause of it.
Been a veeerrrrrrryyyy long time since i checked a code with a paper clip, but I think you jump from A to B in the diagnostic connector under the dash with the key on, engine not running.
Sounds like it's lean. An IAC doesn't usually cause this kind of problem.
How does it flash the codes? Or better yet how do I decode the flashes?
When you ground the diagnostic terminal in that connector, it flashes the check engine line. Each code is two parts. For example, it should flash a code 12, three times, to start. This indicates the computer is capable of communicating, it's not a problem.
It will flash once, pause, then flash twice. Pause again and then repeat the previous. It will do this three times.
After the code 12, it will flash the real trouble code(s) in numerical order and repeat each one three times. If there are no codes, it will just keep flashing the 12 over and over until you unground the terminal.
If you had a lean code, which is 44, after the 12, you'd get 4 blinks, a pause, 4 blinks. That'd repeat three times.
Thanks.
CHECK THE GASKET UNDER THE TBI, IF IT HAS NEVER BEEN REPLACED TIME TO REPLACE, LOTS OF PROBLEMS WITH 88 89 350'S WITH TBI. SPRAY SOME WD40 AROUND THE BOTTOM OF THE TBI IF THE ENGINE SPEEDS UP AND STARTS TO RUN BETTER THAT IS THE PROBLEM, THREE BOLTS REMOVE IT AND NEW GASKET UNDER 10 BUCKS...
I agree. Replaced a lot of those throttle body gaskets myself. I will say, however, that in most cases, they seemed to cause a high idle and not an irratic idle. But it's been a while and I may not be remembering all the particulars.
MTRMAN5, you might want to try turning off your CAPS lock.
Okay I got a 15 and 45??
So that's Rich Exhaust? and a coolant senor?
Yep. And the 15 (coolant sensor) could result in the 45. 15 means the ECM sees a high voltage on the coolant sensor circuit. That means the sensor's not pulling it low so it thinks the engine is cold. Maybe very cold. If there's an open circuit in the coolant sensor circuit, the ECM sees that as -40 degrees.
If it's -40 degrees, the ECM is going to inject a LOT of fuel to get the engine started and keep it running. If it's not really that cold, it's going to run very rich (code 45).
The sensor is in the front of the intake manifold if I recall correctly. Two wires, one yellow, one black. We used to see those wires badly deteriorated right at the sensor connector. Also had the rare case of the sensor leaking coolant, and with the weather tight seal of the connector, it would pump coolant through the harness insulation all the way back to the ECM. That's not very common, but it can happen. Usually, it's the wires insulation falling apart right at the connector.
Anyway, that's where I'd look first. Could be a sensor too.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 417 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
