Predator and Emissions Testing
OK sure it's no biggie to deprogram before an emissions test but thought I'd ask anyway. For the first time ever starting in Sep05 the Austin TX area will start emissions testing. And 95 and earlier years will have to pass a 2speed idle test. I wonder how this will affect those that have had extensive engine work done, like bigger cams, etc, that seem to produce pretty strong unburnt gas smells at idle.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
