Make your own led turn signal mirror
So what would go wrong if I tried it....
Broken mirror for sure...
burn myself soldering...
200 ain't so bad. :thumbs:
Thanks for sharing. Looks good enough and sounds easy enough. Whos gonna try it first.
Cool idea - I'm willing to try it but right now I've got no time to do it. Unless I had a pair of spare mirrors to try it on.
Did find the LEDs for relatively cheap, less than a buck each. And I agree with the guy, who wants to pay $200+ for mirrors with turn signals?
Besides, the GM book describes how to remove the glass so it must be possible. As for burning my fingers, been there done that too many times. Want to try out one of those Cold Heat tools and see if it's a gimmick or the real deal - maybe this is the project for it.
I'll give the man an "A" for that one, but he didn't use GM truck mirrors. I just popped out a mirror to take a look and found that the heating element can not be peeled away like the one he did. second, an led doesn't shine through the coating on our glass like it did on his but that might be because this mirror is one of the dimmimg mirrors. Where the LED's are positioned the mirror coating is louvered so the light can shine through the lines.
Third thing I noticed was that our glass does not separate from the plastic, it is bonded on almost the whole surface.
Here is the back of a factory GM mirror.
I tried very hard once to remove the mirror glass from its plastic backing. I was very slow, meticulous, and used a heat gun. The mirror broke anyway. :D
You can peel the heating element away from the glass and the LEDs WOULD shine through, but I doubt you could get the glass off the plastic backing without breaking it.
I bought OEM heated, autodimming, signal mirror glass for $60/pair from a guy once that advertised on another forum. I don't know where he got it, but it was brand new and he had several pair to sell. I think if you can source it from the manufacturer, it's probably pretty cheap.
Don't mean to skew the topic, but I received the Coleman Cold heat soldering iron for Christmas. It's pretty cool, but fragile. The tip is composed of two seperate pieces and it uses the area you are soldering as it's switch. when shorted to the work surface, I'm assuming it flows a lot of current through and heats up the connection. It's hard to get a good connection to keep the iron on, the tips will get hot enough to burn you if you have it flowing a large area, and the tips are a little bit harder consistancy of a graphite pencil so you have to be gentle.
good luck w/ the led mirrors, sweet find!
I'll second every bit of that. I broke a bit off one side of tip of mine within 5 minutes just because I didn't expect it to be that fragile. It doesn't seem to work well on larger parts where it has to heat more area, but worked fine on soldering wires together and such ... when I could get it to maintain a connection that is. Of course I'm all thumbs anyway so that didn't help. :D
The OEM heated, dimming, signal mirrors are made by Gentex, Thats is what is onlt the back of the one I removed to look at. You can see it on the above pic right under the heating pad connections.
If you go through a GM dealer, MSRP is almost 400 dollars PER MIRROR. Mine was failing on my drivers side of my 2004 Silverado. It wouldnt always go back to where it was when you power folded it back out. Thank goodness for warranties. I looked at the price when they were looking it up to order, what a ripoff. I always wondered how one could go ahead and do it themselves if they had a few tools. Its nice to see someone finally came up with a decent plan. Too bad it doesnt work for everyone.
    HWN808
    HWN808
  • Who's Online   2 Members, 2 Anonymous, 1,036 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
