SoCal ZR2 club!
rspillc
Hello all!
Got a brand new 2005 Blazer ZR2, and looking for fellow ZR2'ers out here in SoCal to possibly form a club of sorts.
What do you say SoCal??
Rex Pascual
[email protected]
Welcome.
Tell us more about your Zr2. Is it one of those fancy "RWD" versions?  :chevy:
Post pics!!!!  :chevy:
Actually, it's the 4X4 ZR2 with the instatrac shift on the fly 4 wheel drive. Pretty nifty too!
The plan is to either put pack a supercharger between the fenders to wake up the sleepy V6, or shoehorn a small block V8 between the fenders. But that's in the distant future.
Anyway, was looking for fellow ZR2'rs in SoCal who would like to form a ZR2 cruisin' cl :D:flag: ub.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
