Red Neck Stereo
Scyry
Good grief, that's horrible!! That worse than my friend's sister's car. The idiots that installed that left about 20 feet of wire under the carpet. They didn't even bother to wrap any of the connections with electrical tape either. Her parent's didn't know what was draining the battery until me and friend put the original radio in. That was the worst butchering I've ever seen in a car too, with the exception of farm trucks.
LMFAO!
I know a guy who had a busted ass BMW (in an impound yard now) who had speaker wire coming out from the dash and going over the seats and s**t. He used electrical tape to hold the wires as well and of course nothing was soldered.
