Installing new radio w/sirius satellite radio
Got a Kenwood sirius satellite ready deck that I'm installing in my '98 Yukon. Everything looks very straight forward. My truck has the separate CD player in the dash, is that easy to remove?? Anyone know the part number to the little cubby trucks without CD have??
Only other concern I have is running wire from satellite antenna on roof. I'm assuming I can run it into the cab above the rear hatch easily? Any tips on this?
Thanks
Not sure about the part number on that pocket. I ran my XM antenna wire thru the 3rd brakelight hole, that may be an option if you have a similar setup. :chevy:
Thought I had the part number, but can't find it. But as far as the CD removal, it is just like the radio. Squeeze the tabs, and it just slides out.
I also ran my Sirius sat antenna through my third brake light, and siliconed it to asure it was weather tight. as for the reciever i mounted that to the fire wall. it was REALY easy. didnt even need to drop the roof.
Thanks
I ran my antenna to the passenger side dash, up to the front. Very unobtrusive and the only time I have reception trouble is when my wife puts her crap over it during a car trip. Another bonus is it doesn't scream to every thief walking by that the satellite radio is there!
'Puckfan
Thanks
'Puckfan
I had mine on the dash for about a week, until I could get time to run it through the headliner. Reception faded everytime I turned north. Works great on the roof now. My roof already had a hole from a cell antenna from previous owner :chevy: but it worked out well for the antenna. My is in the front part of the roof racks and you can't see it at all.
Thanks guys for all the help!! I think I'll try to go out to the roof through the 3rd brake light. Just need to pull the rear headliner down a little to access it?? I'll be tackling this project probably tomorrow, so any more tips are welcomed.
I installed my Clarion Calypso in my suburban a couple weeks ago. I was going thru my third break light as you described and I was about 18 inches short on cable. Before you go thru the trouble, measure your cable, then "route" where your cable will be with a string to see if you will have enough cable. Kenwood may give you more or less cable than Clarion??
I mounted mine on the roof just above the windshield and ran the cable behind the windshield rubber, and into the cab thru the hole for whe door power cords.
Check out this site too, there is a ton of information there and very helpful people too.
http://www.siriusbackstage.com/forum/
The installation garage there is great!
elwood 2000, I should be all set with cable, think there is 21' with the antenna to go to the Sirius receiver and another 8' to go from receiver to the Kenwood deck.
thirdgoat, thanks for the tip for the dash pocket to fill where the CD was. Just ordered one from CKresto. Got a catalog coming too, never heard of them before.
Well I attempted swap and found a mess. Apparently my radio has been swapped out before. I removed it to find the wires had been all hacked then half-assed back together with crimp connectors. Guess I shouldn't have soldered a GM radio plug to my radio harness. What I'd like to do is find a stock plug for the truck side of the radio so it'll be a clean swap, any ideas where to find one??
At the very least I need a factory wiring diagram of the radio harness so I can sort out this mess. Did a little searching the web to no avail. Help. :cheers:
Click the links for pictures of the plugs and then the functions are listed below.
Plug1
Plug 2
They are 2 sperate plugs but they are actually attached together into one unit on your truck.
Connector Part Information
12047531
10 Way F Metri-Pack Series 100 (BLK)
Pin
Wire Color
Circuit No.
Function
GRY
118
Speaker Return, Left Front
2
TAN
201
Speaker Feed, Left Front
3
DK GRN
117
Speaker Return, Right Front
4
LT GRN
200
Speaker Feed, Right Front
5
BLK
150
Ground
6
PPL/WHT
1382
LED Dimming Signal
7
GRY
8
Instrument Panel Lamp Feed
8
PNK
314
Radio On Signal (Suburban/Utility)
9
YEL
43
Fuse Output Accessory, Type III Fuse
10
ORN
1140
Fuse Output Battery, Type III Fuse
Radio, Connector C2
12065785
10 Way F Metri-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
11-14
Not Used
15
DK GRN
835
Diagnostic Signal--Entertainment and Comfort
16
DK GRN/WHT
817
Vehicle Speed Signal--4000 Pulses per Mile
17
LT BLU
115
Speaker Return, Right Rear
18
DK BLU
46
Speaker Feed, Right Rear
19
YEL
116
Speaker Return, Left Rear
20
BRN
199
Speaker Feed, Left Rear
Thanks, 99-2door!! :)
So I got everything in and working okay. I ran the Sirius antenna wire through the 3rd brake light, worked great, looks clean.
Now I have new problem, there is no sound from my middle speakers in the rear doors. :cool: To be honest I can't even remember if they were working with the factory stereo or not, but I do know that I only have front door speakers and speakers over the rear gate working. There is only wiring at the deck for front and rear speakers, how are the middle ones connected???
The 4-door Yukons and Suburbans have a amp module under the driver's seat for the rear door and cargo area speakers.
Most likely the guys that screwed up the wiring in the dash by-passed that and wired directly into the rear speakers.
To get all 4 speakers working again you will have to get that amp wired back up correctly.
If you take out the seat to have a look, don't confuse the airbag module with the amp.
    DLZ
    DLZ
  • Who's Online   1 Member, 0 Anonymous, 575 Guests (See full list)
