Used Edge Juice Module
Latest version manufactured in 04. Looks new. You can add the attitude display to this unit as well as an EGT probe. Comes with original box and paperwork. Guaranteed. Install is 5 minutes under hood.
125 HP increase available with this unit, for $2/hp. 5 levels of power. Does not program the ECM. When removed, there is no trace of it having been installed using the Tech II. Hands down the best HP value available for the diesel. Retails over $600. Will sell for $295 plus shipping.
Also have an attitude display for $135 pl shipping (free shipping if purchased with juice). Ver 1.5 mfr date 1/04, like new
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
