Need advice on accessories for 2500HD
Hi Everybody,
Just bought a new truck to replace our aging Sub, got a blue 2500HD DMax crew cab (I'm selling my 350Z for this!). I just started reading this forum and some of this has probably been discussed before, but the search function isn't working for me, so hopefully you can help me out.
Here's what I'd like to add (initially ;):
- cap: like the looks of Covermaster and A.R.E., but A.R.E. doesn't seem to have
one for the 2500HD CC/LB (in the Z series, which I like)
- liner: probably the Turbo-Liner (spray-on)
- step bar: stainless or stainless/chrome (incl. hardware), sturdy and safe,
non-fading steps
- digital brake controller
Any advice, info, experience, with any of the above? Also, if you've purchased from on-line retailers, any good or bad ones to look out for?
Thanks,
Frank
Depends on what you are using the truck for. I assume towing becasue of the d-max.
I am set up for work so I can't help you on caps. I need full hight access to the bed for patio doors and loader loading. My "cap" is 2 side mount tool boxs with a rollup cover over them.
Bed linner is a piece of plywood. (only thing I have found that will hold up to fork lift loading.)
I use running boards instead of steps because they keep the mud from covering the sides of the truck and windows when on those new "no driveway yet" sites.
I can recommend a brake controller. I use the prodogy. It works real well. I tow a dump trailer which varies in weight from 1800lbs empty to over 9000 full. All other controllers, I have used, had to be readjusted with each change of trailer weight. The prodogy seems to adjust itself. I always have brakes but even after dumping a load I don't lock up the trailer wheels.
I got my Prodigy at RJays:
http://www.rjays.com
Good service and price I thought
I put on the chrome "GO RHINO" side steps. Can't really comment on chrome or stainless but get the wheel to wheel. Really nice for access to the box.
I have an ARE Z series for my 01. Love the looks and the way it works. I looked at all the toppers when I was buying and decided to go with that one. Very suprised that you say they do not have one for your truck. I have a long bed, but do not know the differences between your year and mine. Check their web site. I am sure one is in the works if they do not have one already. Only thing I did not get that I should have is the fold in window for cleaining. Nice option and wish I got it.
For steps I just put on a pair of Westin CPS. Chrome over stainless steel. Very nice fit and finish and a lifetime warranty to boot. Coat me a hair over 400.00 but worth it..
I got the Westin running boards. With the flaps on the front tires and running boards no mud build up right in front of the door.
I also recommend the Prodigy.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
