whining noise
All,
I've had my 05 1500HD 6.0L for about a week now. When leaving for work in the morning, a whining noise comes from the engine. It sounds a lot like a pwer steering pump going bad. The more throttle I give it, the louder the sound becomes. The sound slowly begins to go away and is gone in 20-30 minutes. The dealer is trying to tell me this is normal.
Has anyone else had this experience?
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
