Suburban/Tahoe headphones
On our Suburban, we have the factory DVD entertainment system with wireless headphones. They work great, but they are too big and bulkey for my 6 year olds little mellon. There are headphone jacks on the back of my center console with a selection button and a volume control for each side.
I looked in my manual and in one place it says that the wired headphones are for AM/FM/CD, but not for the DVD system. Later in another section, it says that you can select AM, FM, CD, or DVD while using them. :fume:
I would like to buy a smaller, lightweight set of headphones for my daughter for when she listens to the DVD via headphones, but I am unsure if they will work. I like the idea of the kids watching a DVD and listening via headphones while I and my wife listen to the radio or satalite radio in the front.
Before I go and buy headphones, will they work?
Thanks! :cheers:
Hey Elwood, I plugged in a cheapo computer speaker that I stuffed into my kid's car seat so she can listen to her DVD or CD audio seperately from us. You'll need an extension cord so the kids don't yank the plug out of the jack. And you are right, the wireless headphones are pretty chunky.
DVD is selectable on the wired jacks on the rear console. But GM managed to screw this up......you cannot listen to XM up front if the RSE is set to DVD. On long trips we end up listening to CD up front if the kids are watching DVD.
Interesting thread.
I've managed to get my four year old to keep the clunky wireless headphones on her head...and my six year old does just fine. Never had to resort to the wired connection (didn't even think it would work)
I will have to go home and try this...
I have 3 kids and they use the wired headphones all the time. It is the best option I could ever get on the Tahoe! I don't have XM so I can't comment on that. As far as radio, CD, & DVD. Any of these can be selected and controled from my rear unit. The only stipulation to that is if the back and front are set on the same input the people in the rear can't adjust it. I like this because the 9 yr old keeps trying to change my radio station and gets mad that he can't change it when I'm listening to it. We always listen to the radio in the front and kids get to pick from 6 cd's or a dvd in the back. Only complaint with the rear plugs is they don't have allot of power. I sometimes have 4 headphones on 2 jacks and they turn them up all the way and they are still not loud. I have bought a cheaping booster/splitter and radioshack and all is well now.
Best Family travel moment ever. Listening to the race on the radio up front and all 3 kids are singing the wrong words to cher in the back seat with the headphones. They didn't even notice mom and I laughing so hard we were crying. Kids are 5-8-9 - I wish I had a video camera. It was hilarious.
Thanks so much for the replies!!
The problem is not so much keeping the headphones on her head as much as it is they give her a headache. They are big and do move around a bit on her head, but I think the force squeezing hurts her ears. (That is what she says)
Now that I am going headphone shopping, what brands/types are good quality?
I have seen the little "hooks" that go over your ears with the earpiece that sits just inside your ear. Are these any good or should I look for something like the factory ones, just a LOT lighter and smaller?
Thanks for the help. We are going to Myrtle Beach in a couple weeks and I want the entertainment issues resolved before we leave!
:chevy:
I dunno--maybe ones with cupped earpads? What I mean is headphones with the center of the earpiece hollowed out, vs. the GM OEM headphone earpiece, which is just one solid piece of foam padding.
And yeah, the RSA/multi-source issue is annoying--dunno why GM decided to engineer but one AUX input on the factory radios found on the NBS trucks/SUVs. I have it worse--since I have a nav radio, my non-radio sources are the slave CD changer (can't play a CD in the nav radio--otherwise, no nav function), XM, and DVD--all shared on the same single AUX input.
Get cheapo headsets - regular over the top of the head from Big Lots or Target. They are light and tend to be smaller without the tight springiness.
Kids are rough on this stuff anyway - you'll probably go through several sets as the plug gets torn off, wires pulled out and missing foam pads. I suppose my only concession would be if my girls wanted pink headsets or something.
I'll be sure to not let her read that statement! She is a Diva in the making anyway! :sigh:
Thanks for the advice! :chevy:
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
