1999 K3500 5.7 Auto 115,000 Miles. NEW: Cap, Rotor, Wires, Plugs, Fuel Filter, Crankshaft Position Sensor, Camshaft Position Sensor and I am still getting a CEL code P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation. Any thoughts.
You must do a crankshaft posistion sensor relearn procedure whenever you replace the sensor. You will need someone with a Tech2 like the dealers use or similar tool. Not difficult or expensive!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
