8.1 fuel mileage help
I'm new to this board and am not getting search function
to work. I sure that this topic has been gone over many
times, But, what the heck.
I just bought a 2005 GMC 2500HD with 8.1, with allison tranny,
I knew mpg would be bad, I acepted that from the getgo, but is there
things that I can do to help. Mostly thinking about cold air intake and
daul exhaust. Pickup is mostly used by wive to get to work, less than
3 miles one way. Thanks
Welcome :chevy:
I only have 1200 miles on my truck - I commute into town at +/- 60 mph for a roundtrip of 35 to 50+ miles 50% thru traffic depending on where I'm picking up my badazz kids from day school/care. Anyway, I'm averaging a fill up everyday 6 or 7 days & getting mid 11s. Not sure if the Allison combo would get the same.
I live at 7000 feet so the first thing I plan to do is get a Volant intake maybe a Magnaflow exhaust. I think the best thing to help MPGs is to let up a little on the good foot. :seeya:
moo
Skip the duals, get a GOOD intake system and a Wester's custom tune and drive it like THE BIGPUNN suggests.
I live at 7,200 ft and if I drive it like an old man I can get 14.1 on the highway at 55 mph. As soon as funds become available the intake and the Westers is going in.
DEWFPO
I drive 6mi each way to work and do almost no highway driving. I consistently get 9.5 to 10.5 and I do not drive it easy. Only performance mod is dual flowmasters (wich sound ridiculously cool) and I will be sending PCM to Wester's soon. I have 3.73 gears and get only 6.5 when towing my 21' Bayliner (5000lb ish). :chevy:
I added a Westers 87/89 tune to my 8.1/Allison 04 3500SRW, and an Airaid intake, mileage jumped over 70 miles/tank. More preformance and a solid 12-13 MPG rual/town driving. Haven't had it on a trip to see how it will do on the highway.
Bill
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,536 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
