Changed the oil in the trailblazer for the first time and was wanting to know how many grease fittings are there. Did not see any. Anybody know????
You found them all! :banghead:
(There aren't any) :rolleyes:
  • 3 weeks later...
  • 3 weeks later...
How does that work? I have an H3 and it doesn't have any grease fittings either. Although the manual says to grease the usual locations. Does it just not get greased? :confused:
How does that work?  I have an H3 and it doesn't have any grease fittings either.  Although the manual says to grease the usual locations.  Does it just not get greased?  :cheers:
They are a sealed fitting, no need to grease. When it breaks/leaks the whole fitting needs to be changed. I had 2 go so far.
How long should we expect these sealed fittings to last before needing replacement?
Hard to tell, most last a good long time about 10 years. My vette is 6 years old and all of them are fine.
You'll see when they break, you'll see grease all over the wheels and suspension.
