03 Trailblazer Question
Bullethole
Looked down at my speedo the other day and I was goin 65 in a 55. Absolutely knew I was not going that fast. Grabbed my handheld gps and determined that the speedo was exactly 10 mph too fast. When I came to a stop the pointer went down to 10 mph. I pulled over and and restarted the engine and the speedo reset itself. Should I be concerned? This kind of crap worries me.
That would worry me too. I didn't have that sort of issue with my 2003 but if I had I'd definitely take it in for service. Odds are that unless it's doing it when you take it in they'll say there's nothing they can do about it, but at least you can get it on record in case it happens in the future.
(Maybe I'm making a bad assumption- any remainder of the warranty left? If not, definitely wait until it happens again before taking it in if you can.)
