Wiring Schematics
Guest chevydeerhunter
I was wondering if anyone knew where I could find the wiring schematics for the passenger side dash panel?
Sorry, 2wd. Looking at the panel on the passenger side of the dash. I was wondering if there was a good power source to hook my Soundgate adapter for my Sirius satellite radio. Thanks!
I do not know what a soundgate adaptor is, but I can tell you that there should be a empty hole in the fuse panel that says accsy or something like that, you can get a tap plug from the auto parts store and plug in there, other than that, I would say tap the power wire that feeds the factory radio. I will keep looking for the diagram for you though and post it if I find it. I have the eservice manuals.
The factory radio on the 03-up trucks doesn't have a ACC 12V+ feed. It only has constant 12v+ and a signal from the BCM truns it on and off.
You will have to run a wire to the driver's side junction box. There isn't one in the passenger side box either.
I used the cig lighter power for mine.  It doesn't require alot of power.  Plus it is always on, and you need it to be always on for the memory in the soundgate adapter.
Pics of my install
I really appreciate the pics! I installed a Visor Shelf-It system in my truck and they have power ports which I tied into the lighter. The only thing I have running off of it is a radar detector so I don't think it's drawing too much power. Is that the KTC-SR902 tuner you're running? I've heard that the replacement SIR-KEN1 is trash compared to the KTC-SR902. What antenna did you use with it?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
