happy birthdays
R Dogg 56
SnakeEyes 325is(20), ps496(39), carl722(32), myblazer(29), fdsjr(20) :cheers:
Is is me, or is there only one name on here that I recognize? Where is everyone?
Thnak R Dogg!!! Your the first one on here to ever wish me happy birthday! lol!!
The house thing is going good. over at my parents now enrolling in auto bill pay stuff online, but the electric company's site is inproperly coded so I will have to do it over the phone.....and the gas company require you to fill out a paper by hand.....forget that idea!
The camaro's plug wires are melted so I can't drive it more than 6 miles at a time until I get some new hi temp wires on. Hopefully I'll have a computer in not too long and hit the boards again!!!
thanks again, see you guy later!!
