5.7l cold start hesitation and stalling
I have a 99 GMC full size truck which is the old style still and has 5.7 engine. The truck starts fine but has a bad hesitation when cold at idle, it will "miss a beat". It will stall periodically too. If I take out when cold it wil spit and sputter when accelerating normal. If I floor it then it will accelerate fine. Truck runs fine when warmed up. It acts like bad plug wires but they are new as well as plugs, new fuel filter as well. Also put on a throtle position sensor on too.
No light coming on on dash.
Any help????
Craig
Had the same problem with my 98. All I did was run some injector cleaner through it and it is noticely better but still not 100%. Some one told me that it could also be the injectors or a vaccum leak.
Jim
Big Wheelin, where exactly is the fuel pressure regulator. I will look at it tonight to see if it has a leak.
Also, truck seems fine when it is warmed up as well.
Any help????
Craig
Had the same problem with my 99. However mine is the 5.3L and newer body style. It turned out to be the fuel pressure regulator ($50). After it is warm, shut it off and pull the vacuum hose off the fuel pressure regulator and see if gas runs out of the vacuum hose. If gas comes out it is a bad regulator. The one on my 99 is on the drivers side on top of the valve cover about mid way from front to back. The only vacuum line coming out that side goes to the fuel regulator. I don't know if the 5.7 is set up the same. Good luck.
I'm having the same problem in my '02 6.0L. If it's a little cold outside, it'll hit on a few cylinders, but, run for a second like it's running out of gas. I've checked the pressure regulator, and think that's fine. I'll check it again this afternoon.
Would anything else cause pressure to be released from the fuel line (check valve, fuel pump, etc), causing the fuel to run back down into the tank, therefor causing the hesitating starting?
  • 4 weeks later...
  • 3 months later...
I had the same problem, turned out to be the intake manifold gasket. It would rev between 300-1100 rpm's while idling. I could gun the engine and try to get it warm quickly and then all would be okay until the next morning.
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 591 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
