aluminum 5.3 HO? yes/no?
can someone please help me out.  i am in a debate on if there is such thing as a 5.3 HO aluminum block engine.  the chevy site says there is.  anybody know?
Yes but currently only available in an extended cab 4x4 1500.
Are you talking about the Vortec 5300? I bought a new one last week in a regular cab, extended bed 4x4 1500.
There is no extended bed only cab. For 05 its only available in the extended cab 4x4 1500. Its rated at 310 hp.
the L33 is the 5.3L H.O.. it is rated at 310hp and has an aluminum block/head combo. i'm not sure yet for 06', but for 05' it was only available in the 4x4 extended cab truck.
the L59 and LM7 are the standard 5.3L and use a cast iron block. for 04' and up they are rated at 295hp. they are available across the board.
my boss just changed his demo and the new truck has the L33. it is a much better 5.3L than his last one which was an LM7 truck. the new truck has an outlaw airbox and corsa catback waiting to be put on. from there i'll program it and we'll track test it.
Are we talking about the Vortec 5300? If so, I think you are confused.
This one is very close to what I got:
2005 Silverado 1500 Regular Cab Long Box 4x4
VORTEC 5.3L 295HP IRON BLK V8
4-SPD AUTOMATIC TRANSMISSION
BLACK
DARK CHARCOAL
VIN: 1GCEK14T45Z189684
MANUFACTURER'S SUGGESTED RETAIL PRICE
STANDARD VEHICLE PRICE...........................$ 24,210.00
Options installed by Manufacturer
LIGHT DUTY POWER PKG DISCOUNT...............$ -1,000.00
REAR AXLE 3.42 RATIO..................................NO CHARGE
GVW RATING - 6,400 LB................................NO CHARGE
BASE DECOR INCLUDES................................NO CHARGE
40/20/40 SEATING
AM/FM STEREO W/CD PLAYER
CHROME STYLED STEEL WHEELS
BODY SIDE MOLDINGS
LIGHT DUTY POWER PACKAGE:........................$ 2,370.00
VORTEC 5300 V8 SFI GAS ENGINE
LOCKING DIFFERENTIAL-REAR AXLE
HD TRAILERING EQUIPMENT
HEAVY DUTY SUSPENSION............................$ 95.00
4-SPD AUTOMATIC TRANSMISSION...............$ 1,095.00
TOTAL OPTIONS..........................................$2,560.00
TOTAL VEHICLE & OPTIONS..........................$26,770.00
DESTINATION CHARGE................................$850.00
TOTAL VEHICLE PRICE*...............................$ 27,620.00
You have the IRON block 5300
The 5300 HO is an ALUMINUM block which is rated at 310hp.
The 5.3 HO is only in an Excab 4x4 or Z71 1500
No, I think you are confused. My truck has a regular cab, the
Votrec 5300 and is not a Z71.
Please read the **entire** post below.
BLACK
DARK CHARCOAL
40/20/40 SEATING
BODY SIDE MOLDINGS
Look at the RPO numbers on the sticker inside your glove box, L33 is for the 5.3 HO.
This here is information off the GM site:
(L33) Engine, Vortec 5300 V8 SFI with 310 HP @ 5200 rpm, only available on CK15753 Models
AVAILABLE MODELS
2WD Regular Cab Standard Box (CC15703)
4WD Regular Cab Standard Box (CK15703)
2WD Regular Cab Long Box (CC15903)
4WD Regular Cab Long Box (CK15903)
2WD Extended Cab Standard Box (CC15753)
4WD Extended Cab Standard Box (CK15753)
2WD Extended Cab Long Box (CC15953)
4WD Extended Cab Long Box (CK15953)
2WD Crew Cab Short Box (CC15543)
4WD Crew Cab Short Box (CK15543)
**L33** NEW! Engine, Vortec 5300 V8 SFI, aluminum block with steel cylinder sleeves (310 HP [231.4 kW] @ 5200 rpm, 335 lb.-ft. (452.3 N-m] @ 4000 rpm)
*1 - Requires CK15753 Models and included with (PDU) Light Duty Power Package. - Not available with (NYS) 4-wheel steering.
jjo31420, read the above posts, there are TWO Vortec 5300 SFI engines available in the 1500. One is yours, the 295 HP iron-block V-8. The other is the 310 HP aluminum-block V8, AKA the HO version.
Yes jjo,You DO NOT have the "L33" alum.block "HO" 5300-V8.
The "L33" alum.block "HO" 5300 IS NOT available in any Reg.cab truck,ONLY ext.cab's.
Your truck has the "LM7" 295-HP iron-block 5300-V8.
It is not available in the 4X4 extended cab, if you get the long bed. :confused:
I don't see too many people with my truck...
Yep I do believe that they are the left over motors from the SSR. My buddy got one in his brand new GMC Z71 and it runs good.....
Look on the VIN. The 8`th digit is a "T" on cast iron 5.3 and a "B" for aluminum block HO 5.3. "T" can be 285 or 295 hp but both are cast iron block.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
