2003 Tahoe not starting
I have a 2003 Tahoe 5.3l and this past Sunday it decided to stop starting. It would crank and catch but as soon as it sounded like it was on it died. I then had it towed to the chevy dealership where they could not duplicate the problem. So I went to pick it up from the dealership yesterday and drove it around the rest of the evening. This morning i go to start it and experience the same crank, catch, and die. I would be grateful for anyones advice or suggestions on what to look at next. Could it be something as simple as a dirty fuel filter or something as serious as the fuel pump? Either way I would be happy to pay for either to get fixed if I just knew what the problem was.
R Vela
SGT USA
BAMC
R Vela
SGT USA
BAMC
Sounds like what happens when the security system is tripped. It will crank & fire and dies immedietly.
Is your security light staying on after it dies? If it is it may be the security system doing it. If the security light isn't coming on after it dies it is a problem elsewhere.
If your security system isn't tripped when it does this I would get a fuel pressure regulator and see how the psi looks. I believe these trucks should run in the 50-55 psi range when idleing. PLEASE correct me on the PSI. I'm going from memory here.
When they were installing my remote start they had problems whith the security system and would have to let it sit for 20-30 minutes before it would start after they tripped it.
I had the same problem with my truck it would start and the die if you wait about 15 to 30 minutes it will start and stay running. Turns out it was the pass lock system dealer ship will overlook it every time. It is a pointless security system. Let me know if it works post results on the fourm.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
