05 Silverado Easy Exit Seat
jafount
Posted in the main forum too. I have an 05 Silverado. Is there a way to make the easy exit seat return to the programmed position when inserting the key?
Thanks in advance.
"The Body Control Module software version determines the personalization features available. Standard software is the factory installed version and allows memory seat, mirrors, and adjustable pedal positions to be recalled from the Driver Door Memory Switch only."
Thanks very much. Final question, is there a way to update the software to incorporate the additional option?
Quite honestly, I haven't done one or looked into this. I assume it's a simple recalibration of the BCM which you would have to pay to have done.
Oh, and I think all the "enhanced" software does is return the memory feature to the key fobs. Not sure it would have anything to do with what you want. But I assume if the seat returns to the position for that numbered key fob, you wouldn't need it to move on key in.
