1999 GMC
kanadaka
Hi I have had problems with my 4wheel drive coming out of 4X4 as it does not want to come out. A scan of the codes revealed C0387 (Unable to perform shift) & C0323 (T-Case Circuit lock low) I looked the codes up but have no idea what they mean or what they suggest should be checked. Do you have any suggestions besides the encoder motor? ATC control module maybe ? Im just asking this because ive read others had different codes when the encoder failed. Thanks for your time
1999 gmc sierra w/auto 4X4
The only suggestion I have is to thoroughly diagnose each DTC to see where the failure is... most likely encoder motor rather than the TCCM, though there could be some wiring problem too. This is not something one can guess at.
Thank you Sir. Your input is much appreciated.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
