New Gas Saving Device
OnBelay
Wow....I gotta come up with some stuff like that. $41 for a piece of scrap 2x4!!! I might just be a millionaire and not even know it!! :thumbs:
hold on now that's not JUST a scrap 2x4, this is a patented fuel saving devise. any reproduction of this model could result in federal jail time.
Q: I'm dylsexic. Waht sfatey precuations are there to esnure taht I dno't put it under the worng pteal?
A: Darwinism will make sure that if you put it under the wrong pedal, you won't do it again.
:nopity:
:driving:
It's gone.
Bummer. Would have liked to have seen it.
