Need some cam sensor help again.
I need some ideas hear. I had some sensor clearance issues with a Cloyes double chain and input voltage low code. Raylar gave me a part # for a GM cam sprocket and a new sensor to work with it. I installed them today. It eliminated the clearance problem but I'm still getting a cam input sensor voltage low code. Should I put the stock sensor back in or could it be something else.
I think there might be a relean needed. don't if that will solve, cause I know with hptuner's scanning I can do a case relearn, suppose is to get crank sensor and cam sensor jiving again. My cam sensor is going out, due hard start condition, after a relearn it will start by looking at the key. Why? cam sensor helps determine some of fueling events. this is just what I been told.
2nd idea:
Either the new sensor is junk(bad) to begin with, or sensor not combatable.
3rd idea: will the old sensor clear and work with new sprocket???
hope this help
good luck
CT
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 174 Guests (See full list)
