ABS Warning Lights
zth2000
I have a 1995 Chevy Tahoe 4x4 with an EBC310 and am having some ABS issues. The sensors, fuses, and motor all check good. The symptoms are that with the engine running, when the brakes are applied first the ABS then The Brake light illuminates. If you hold the pedal down the lights go off. As soon as you move the pedal at all the lights come back on. There are no error codes and the system acknowledges the brake pedal is pushed, i.e., code 12 without the brake code 13 with the brake. I was suspecting the proportional valve was the culprit and decided to disconnect it's switch. With the connector disconnected the symptoms were exactly as they were when it was connected. I tried shorting the terminals in the harness which resulted in a steady Brake light, and no ABS. This would indicate that the switch on the proportioning valve is working correctly.
I can envision a scenario where the pintle is stuck or the switch defective so that it was in a continuously open mode. The controller may not show this as a fault until it receives a signal from the brake pedal switch. The problem with this thinking is that the lights go out with the brake depressed if there is no pedal movement! This would imply that the brake switch is either detecting motion or absolute position rather than a limit condition, or there is a pressure sensor somewhere in the system (which appears not to be the case). Neither of these possibilities feels right.
Any help that can be given would be appreciated.
That's a strange one, particularly the part about hold the brake pedal. I can tell you that the switch in the combination/proportioning valve is simply a ground for the red brake light on the dash. It's not any sort of pressure sensing input to the ABS.
If I had to guess, I'd say your problem is in the BPMV (brake pressure modulator valve). LOTS of problems with those older ABS systems in that area. I'm surprised there's no DTCs though. I'm also not aware of any code 13 in the ABS system. Where/how did you get those codes? I really don't recall if it gives a 12 if there are no codes like the old OBD 1 used to do.
Thanks for the response. The codes are less common but are as follows:
12 = No Problems
13 = No Problems - Brake pedal engaged
14 = No Problems - ABS engaged
I am finding that the documentation is poor for the ABS systems. I am trying to locate a wiring diagram for the system or at least pin connections for the 10 pin connector. As for the BPMV - you have me on that one. What is it and where is it? Is it all hydraulic or does it have a sensor on it? I feel the problem is pressure related but can’t figure out where the ABS system gets pressure information.
After finishing my reply I looked up the BPMV and realized it is what I have always called the ABS valve body. I am reluctant to change this given the painful bleeding procedure. I also don’t understand how an issue with the hydraulics is sensed by the control module thereby turning on the lights. The only point of feedback I can see is the proportional valve brake light switch. Are there any other pressure switches? I have inserted a new switch into the end of the connector therefore eliminating any pressure effects to that circuit and still get the same results.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 366 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
