Infinity Basslink X
6Burgh
After pretty much giving up on having decent bass in my extended cab Sierra I decide to try a basslink on the recommendation on this forum and across the net. I really thought I would be disappointed. How can a speaker in a box that size and being made of plastic put out any decent bass?? I found one on eBay for under $200 so I decided to give it a try. All I can say is WOW. This speaker sounds better then the 2 10" subs I had in there and takes up a 1/3 of the room! My only regret is not getting one of these from the beginning. :dupe:
BTW I am using a PAC LOC and a Alpine EQ on the factory deck which probably helps get the most out of this speaker.
...My only regret is not getting one of these from the beginning. :dupe:
Congrats on taking the plunge! I remember when I first started looking for aftermarket stuff for my '05 ext cab that a guy at Circuit City kind of sheepishly recommended the Basslink. But no-o-o, I was gonna build a superwoofer in a *box*!
Now I know better. Next time somebody recommends a Basslink, listen to them.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
