Is there a fix for the brakes!!??
Hello guys (and gal),
Is there a "fix" for the crappy brakes on my 90 GMC full sized short bed? In talking with other owners of trucks that are close to the same year they say that "the early trucks just had lousy brakes".
Ive rebuilt the breaking system except for the master cyl and power booster but still have to stand on the pedal REALLY hard. I unhooked the vacuum line to the booster to check its operation and had almost NO brakes then(thought I was gonna hafta open the door and drag me feet to stop :D ). That makes me assume the booster is working.
Did GM do something diff on say the 93ish up trucks. Reason I ask is we have three (95 models) 1500 W/T that my company uses and their brakes are fine. You dont have to have legs of a power lifter to get any of them to stop.
If nothing can be done then I guess I'll just throw a power booster/master cyl at it and hope for the best... I just HATE bleeding brakes..
Sounds to me like it's the master cylinder, the booster is working if you had no brakes when you disconnected the line. I'd try the master first.
Thanks for the info bassdog.. I'll prolly just go ahead and try a master cyl but the truck really doesnt do any "weird" stuff when the brakes are applied. Ive messed around with diff ways of stopping (panic, stab the pedal quick but not hard,etc) and it doesnt do anything outta the ordinary. It just takes a LOT of pedal effort. Just doesnt seem right to me.
Ive rebuilt the front/rear brakes and checked the rear adjustment several times. Everything is wearing even/ok so I just dunno what the deal is..
Brakes come in REALLY handy when stopping the truck and a trailer with my Sy on it....  :D  Maybe I should just put a chute on it??!!  ;)
Oh, BTW Moderator(s). Feel free to move this thread if I put it under the wrong topic... Still trying to learn my way around this board...  :D
I think you're in the right spot  :D
Have you replaced the calipers? Hard brakes could also be air in the line/ not bleeded correct??
I'd stick with the master cylinder for now. Someone else may jump in with more info.
Yep, brakes are bled ok. I thought the same as you so Ive bled them a total of 3 times since the braking system rebuild.
I replaced the front calipers when the braking system was rebuilt as one of the calipers was sticking on the floating bolts/pins. Just replaced both of em since I had it all apart and they werent expensive.
To be honest about it, other than replacing both rear wheel cyl that were leaking I didnt notice ANY change in the braking ability before or after all the work..
Pedal doesnt slowly sink to the floor at a stop (like usually happens when a master cyl dies) and I can actually lock all four wheels but I gotta stand on the pedal with BOTH feet to do it. Thats a little too much effort needed IMO cause Im not the smallest/weakest fellow on the planet (6'3"/~225)..
I think I'll just quit procrastinating and get myself out to the garage and put that master cyl on there.. :D
I would suggest that you try a different brand of brake pads on the front. What brand do you currently have on there? ???
The pads I put on are the life time pads from advanced auto. Reason Im not really looking too hard at the pads is that the 1500 W/Ts we have for company vehicles had the same pads installed and they stop just fine. This ones got me stumped. Almost like the booster is bad but not all the way... Still helps some.
To accurately describe how the truck stops would be to take a "normal" power brake equipped vehicle and unhook the vacuum from the booster. You would have brakes but the pedal would be VERY firm. Thats how my full size GMC acts WITH the booster connected. NO brakes (well, very little) when the booster is disconnected.
Goin to the bone yard tomorrow to grab some pieces for another project and may grab a master cyl/booster and throw it on there just to see if there is any change.
Thanks for the help..
How do the rotor surfaces look? If they are chrome-polished looking, they are glazed over, and will cause this to happen. It's like trying to get friction from rubbing 2 flat pieces of plate glass together if they are glazed smooth..theres no friction for the amount of pedal effort you are using, no matter what. If that is the case, rough up the rotors on both sides with some 120 or so grit paper. I would also replace the pads with some Performance friction carbon metallic pads. They improved my braking by a little bit. Keep in mind that if the rotors are so glazed you can see yourself in them like mirrors, the pad surfaces are the same way. Rough up or replace the rotors and break the new pads in gently. Get new pads if this is the case, or the rotors will glaze again and it will not be any better. They will not get full braking ability until they are broken in and making 100% contact with the rotors, and if you break it in too hard, it can create the same situation again. Same thing applies in the rear.. rough up the drum surfaces and check if the shoes are glazed over.
I'd also stay away from the junkyard master cyls. ..you never know what your getting and the master is cheap for a new one which you know the history of. (new usually takes away the gamble of used, but not always) Don't gamble with brakes. It sounds to me like your hydraulic system is fine, theres just no friction there to stop the truck.
I've seen this before, it's pretty common. If you are using organic pads, get the metallics. The organics will cause that glazed condition and polish the rotors to a mirror, which equals no friction, and a lot of pressure to stop.
Just like trying to stop after going through deep water..same effect with wet rotors. Lots of pressure and no grip.
Check it out and let me know what you find.
Also, if you stand on the brakes and lock them, do the front lock first or the rears? Second most likely thing here is a hydraulic blockage where you don't have adequate (or any?) pressure flowing to the rear. If it were not going to the front, your rears would lock right up.. so if anything, you may not have full rear stopping power to assist the front stopping power, either because of a bad proportioning valve or a siezed rear wheel cylinder.
Is your pedal height good?
Also, do you know how many inches of vacuum you have at idle? Sometimes there can be a vacuum leak somewhere which can diminish the effectiveness of the power booster. It needs full vacuum to give full assist. If vacuum is weak, it will cause your condition as well, even if the rest of the brake system is in perfect condition.
I had a '90 Jimmy and the elbow on the TBI cracked and sucked air in. The computer mostly compensated enough so I didn't notice it at first, but the brakes were needing a lot more pressure to stop..which is when I opened the hood and found the leak. Fixed it, and the brakes were good again. (and it idled a bit lower) .. which is another good point.. vacuum leaks cause high idle. Hows your idle? If its high, combined with a vacuum leak (whic is probably causing the high idle) the brakes will need a lot of pressure on the pedal to stop it. Its like trying to stop with you foot on the gas, and half your vacuum boost thrown into the mix.
Also the possibility of a torn diaphragm in the booster, which would create an internal vacuum leak in the booster and have the same effect. Check your idle, then pull off the vacuum line to the booster and block it off. See if the idle is lower with it off and blocked. If it is, you may have a bad booster diaphragm. I'd look at that before the master if it is visibly dry and has decent pedal height. One of these things is causing it, (or a combination of them) but in my opinion, the master is last on the list.  I've done probably over 1000 brake jobs and seen just about every condition.
Also, I know you bled 3 times, but did you do it until it comes out clear? If it's dark colored, theres moisture in the fluid, which can cause the same effect as air. It lowers the boiling temperature of the fluid and can introduce air if that happens. Brake fluid is like a sponge to moisture and humidity. Clear is good. The darker it is, the more moisture content it has absorbed. Flush it right through until it is clear at the bleeders.
The old trucks do have lousy brakes, which is why they have to be near perfect just to be adequate. If you check that stuff out they should be fine.
Hope this helps.
                        Long-winded post guy
:D
check the vacuum reading. Its possible you may have poor vacuum, which leads to weak brake vacuum boost:
testing at idle speed
compare vacuum reading with manufacturer's specification.
a lower reading indicates possible incorrect timing, incorrect valve timing or adjustment, incorrect setting of idle mixture, worn piston rings, or leak in intake manifold.
readings that change slowly indicate incorrect setting of idle mixture screw.
readings that change quickly indicate sticky valve guides, burned valve sets, or leak in head gasket.
b. testing at 2000 rpm
a lower reading indicates possible restriction in exhaust.
oscillating reading indicates possible weak valve springs.
2. Chilton general car care manual.
gauge reading steady 17-22 in Hg indicates normal engine in good condition.
gauge reading low (15-20 in Hg) but steady indicates late ignition or valve timing, low compression, stuck throttle valve, leaking carburetor or manifold gasket.
gauge reading steady but dropping regularly indicates burnt valve or improper valve clearance.
gauge reading dropping gradually at idle indicates choked muffler or obstruction in exhaust.
gauge reading slowly dropping to zero as engine speeds up indicates choked muffler.
gauge reading fluctuating between 15 and 20 in Hg at idle indicates stuck valve or ignition miss.
gauge reading drifting indicates improper carburetor adjustment or minor intake leak at carburetor or manifold.
gauge reading fluctuating as engine speed increases indicates weak valve springs, worn valve stem guides.
gauge reading vibrating excessively at idle but steady as engine speeds up indicates worn valve guides.
gauge reading vibrating excessively at all speeds indicates leaky cylinder head gasket.
3. Haynes emissions control manual
a. testing at various speeds
engine starting vacuum should be 1 to 4 in Hg. To test disable ignition (ground wire from coil), hold throttle
wide open, crank engine slowly with starting motor.
healthy engine at idle should read steady 15 to 20 in Hg.
healthy engine at 2000 rpm should read steady 19 to 21 in Hg.
healthy engine at open throttle should read close to 0 in Hg.
healthy decelerating engine reading should jump to 21 to 27 in Hg as open throttle released.
b. testing at idle speed
low steady reading usually indicates leaking gasket between intake manifold and carburetor or throttle body,
leaky vacuum hose, or incorrect camshaft timing.
low fluctuating (3 to 8 in Hg below normal) reading may indicate intake manifold gasket leak at an intake port or faulty injectors on port-injected engines.
regular drops (2 to 4 in Hg) in reading at a steady rate indicates probable leaking valves.
irregular drops in reading indicates possible sticking valve or ignition misfire.
rapid vibration (4 in Hg) in reading combined with exhaust smoke indicates worn valve guides.
slight fluctuation (1 in Hg) in reading indicates possible ignition problems.
large fluctuation (10 in Hg) in reading indicates likely weak or dead cylinder or blown head gasket.
slow movement through wide range in reading indicates possible clogged PCV system, incorrect idle fuel mixture, or gasket leak between carburetor, throttle body, or intake manifold.
c. testing at higher speeds
rapid vibration (4 in Hg) in reading at increased engine speed indicates leaking intake manifold gasket or head
gasket, weak valve springs, burned valves, or ignition misfire.
reading returns slowly to normal and didn't peak above normal (5 in Hg) after dropping to zero when throttle
quickly snapped open (2500 rpm) suspect worn rings.
reading returns to normal after long delay when throttle quickly snapped open (2500 rpm) suspect blocked exhaust.
d. testing for blocked exhaust
idle speed reading slowly dropping toward zero indicates exhaust restriction.
excessive backpressure in exhaust then indicated by reading not increasing quickly to about 16 in Hg when engine speed slowly increased to 2000 rpm.
backpressure also indicated by reading not dropping as quickly when throttle quickly released and remaining 5 inHg higher or more than normal.
disconnect exhaust manifold from engine and retest. If problem disappears exhaust system is blocked.
to locate restriction reconnect exhaust system one unit at a time testing after each until problem reappears.
I'm leaning towards the booster leaking as well. I'ts probably only going to leak when the brakes are applied, so the part I wrote earlier about pulling the vacuum line off the booster to check it probably won't work as good as listening for a hiss when the brakes are applied. I think if that is leaking it would slightly increase the idle when pressing the brakes too.
I didn't write all that info. on the vacuum testing, it looked interesting so I pasted it.
:sideways:
Thanks for the info 95Yukon.. I gotta head out to work in a few (night shift bites!!) so I'll hafta make this short and sweet (another "long winded" post guy here)..
When I bought the truck (used) the brakes were what I consider terrible.. I found that both rear whl cyl were leaking so the rear brakes had to be rebuilt completely along with new wheel cyls. Had the drums turned at this time also. The front pads were fine but the inside pad on the drivers side was worn ~1/3 more than the outside pad. Caliper was not floating IMO so I put new pins/bolts on that side plus replaced the calipers on both sides (they were cheap and figured I might as well put em on since it was apart). Had the rotors turned at this time also.
Put everything back togeather and tried the truck out... Braking was better but it still took WAY too much pedal effort (IMO) to actuate them. I figured I still had air in the line(s). Bled the brakes twice (got "clear" fluid the 1st time). No improvement. Pedal hight was/is fine.
When doing my "testing" the fronts would lock before the rears but not much before.
Spoke with a bud of mine whos been around GM stuff bout as long as I have and he said "the early years of those trucks just had lousy brakes".. Resorted to just having to stand on the pedal hard for a while but it was one of those things that just "bugged" me. I KNOW they have gotta be better than this.. Drove the truck for 3-4weeks and decided to bleed the brakes again, no air/clear fluid.. No improvement.. Nada, zero..
Thats where Im at now.... Ive got plenty of brakes but the pedal effort to use them is just WAY too high IMO. The disconnecting of the vacuum booster is the quick and dirty test and the truck passed that. If there is a slight leak in the booster then I wouldnt find it that way though. I need to throw my vacuum pump on it and see if it will hold vacuum or the pedal feels better with the engine vacuum outta the picture. The reason for picking up the bone yard master cyl/booster is to see if any improvement or change in the pedal effort was noted. If so then I'll go get new parts to put on permanently.
I need to check the eng vacuum system as most ppl know the plastic/rubber lines get "leaky" due to heat/age. The eng idle is perfect on start up when its cold and at operating temp BTW.
Prolly going to tear into the braking system again this week and see what I can find. If all else fails I guess I could just put a chute on the back or install an anchor in the drivers compartment that I could pitch out the window when I need to stop quickly..  ;)
    Daniel422
    Daniel422
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
