Who's on first? What's on 4.1?
5strinz
Can someone point me to a resource OR tell me the differences in the NAV DVD version upgrades?
Is it programing?
Is it Mapping?
Is it graphic?
I will assume mapping has improved over each version. That is a given. I am confident more roads and accuracy of the roads will be upgraded on each disc.
But what else has been improved per each version? Has anyone documented this?
Thanks, in advance.
Dave
I'm not of much help here, but where did you find this info about the 4.1 Nav disc? My TNR came w/3.0, and I'm very interested in upgrading if possible...especially if they fixed the "poorly assigned street names" issue.
My best guess would be that new versions have updated software AND updated maps.
The 4.1 version is definaletly out there. Exactly what the upgrade is....is anybody's guess...looks like there is no documentation available.
dave
dave
Hi I played with a friends 4.1 disc today I have been using a 3.0 so I got to see what the difference was in my area, mostly more detail, colors added for topographical areas like lakes parks ect, changes in business names some new some out of business, mostly names for small roads that were on the 3.0 disc but not named, some routes changed for programmed destinations.
cheers Bob
dave
cheers Bob
Are you saying that there are now more street names on the screen at any given time? This is the issue that's been driving me completely nuts about by 3.0 nav.... whenever I'm trying to just look at the screen and figure out what street is coming up it never seems to label them. Are you saying this is fixed with 4.1? If so I need to get one right away! Thanks for any info!
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
