MAKE THEM STOP! !! Wipers
So friday, I get the Service 4wd light.,..which is now gone..
Today I turn the wipers on, and they wont go off. So I turned the car off for a few min, and it seemed to operate fine..
Then again it starts up, I They just stay on LOW, no matter what the setting is...off etc. I can get them to go to high, but not OFF
What the hell happened to my hoe!!? The 2001 I had, I never had a problem, I have not even put 3k miles on this one!!!
Same thing happened to mine. The control module shorted out.
Hope you're under warranty.
Yeah I am under warr..
Thing is, its an interment (no pun intended) problem so I hope the dealer does not give me a "can not duplicate" BS line.. Its at chevy now and Im having a list of stuff done to it, so we shall see....
I guess they are going to REPLACE my stearing shaft, so lets hope the clunk goes buh bye!!
And of corse the 4x4 switch works again too! :crackup:
Mine started by doing two swipes (while in intermittent), then one, then three and so on... I was like huh ??? Finally, they just wouldn't stop w/out pulling the fuse.
I would guess by now it should be a *known* issue, but funny how even if it is a known problem, if it's not doing it right-then, they can't help ya :crackup:
Check the tech articles, there is a fix for this, I had the same problem in my 98 and did the fix, have not had another problem. From what I have heard though, even the new circuit boards are doing this after a while. may be better doing the fix, very cheap.
My Escalade started doing this a while back. I'm finally taking it in to the dealer in a couple of days. If they can't fix it, I might like to try the soldering fix. Is there anywhere that tells me where the circuit board is and which joints I need to solder?
Check the tech article section, there are pics and everything. Extremely helpful.
Thanks for the tip. However, I went to the Tech section on this website (the Tech Corner link) and looked through the articles there. I didn't see anything about soldering circuit boards or wiper problems. What am I missing?
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
