Short sound clip
TieRod
Wingnuts. The exhaust is going to revamped next spring for a STS Turbo.
sounds bad ass. what headers do you have? what kind of rear wheel numbers did you have without the raylar goodies? i have the same truck , only ist an 04. i have a westers hot tune, stainless works longtube, and an intake. sure would be nice to have your kind of power- sweet truck
I have TOG headers. The old set up did 290whp and 385wtq. With a Comp cam it did 322whp and 433wtq untuned. As soon as I get it on the dyno I will post up the numbers.
  • 3 weeks later...
