02 Silverado won't start = no power
Wicked70
I have an 02 silverado. I just went out to start it. Here is the sequence of events. Got home from work about 2 hours ago with it. (no prob). I just went out to start it now. I open the door and the interior lights come on. I shut the door and try to start the truck. The starter never engauges but all the interior lights go out and now there is nothing (I mean nothing) no interior lights, no power anywhere. There is a clicking from the fuse panel that sounds like a flasher or relay breaking points. I felt around in there to see if I could feel what was clicking but couldn't feel anything. I open the hood and got out my multimeter. I tested the battery and it was showing 1.5-3 volts. I throw the charger on and that didn't change anything so I took the - cable off and tested the battery again and it shows 12.5 volts. That's when I came in to get some advise. What do you think?
A mulit meter can only show voltage and can't load test the battery.
It sounds to me like your battery, if it is factory it is now 4 years old, is shorting out. A battery can have enough volts to run interior lights and not enough amps to engage the starter.
Pull the battery, take it somewhere and have a load test done, like AutoZone or Advance will test it for free. If the battery is weak it still should take a charge on low amps like 2 to 10.
Good luck.
The battery is about 4 months old. It hasn't even started slow. I have no interior lights or anything. The interior lights worked when I got in. I hit the key and everything whet dark and I can hear the clicking in the fuse panel area on the side of the dash.
Don't be too concerned about that sound. There are motors under the dash that work the blend doors on the HVAC and also relays that click with power.
I would pull the battery post off and reinstall them snuggly. sometimes they can be making contact but not good enough to get the ground. You can also have a broken terminal up inside the battery causing a short. Do you have another GM battery to switch out with? I still really don't think you have a problem with the wiring, like a fuse link burnt, but you never know. Check the battery connections, should be a 5/16th.
I also wouldn't be concerned about the clicking. There are relays and assorted items you may not normally hear when the vehicle starts and runs okay.
As mentioned, it takes very little power to run lights and accessories but TONS more to start the vehicle. Total loss of power when/after attempting to start is classic sign of a poor connection.
I had a similar problem on my 98 sierra. Turned out that the battery cables actually came off the battery posts! Surprised me since I had just tightened and checked them when putting a new battery on not too long before.
dude i had the same prob last nite, battery cable and battery was fine, what the hell
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 657 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
