Air Compressor
My air is hot most of the time and cold seldom and the compressor is constantly cycling. When I short the pressure switch out, the compressor runs constantly. What does this mean? Bad switch or low freon? Thanks
Most likely low freon. But the only way to be sure is to have it checked with a proper set of pressure gauges. Some of the re-charge cans of R134a also come with a gauge so that you dont overfill the system, just read the directions on the can carefully if you decide to try and refill the system yourself.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
